looking for a printer for 2 sides static
bigben
Hi,
I'm looking for a printer to make double sided static and/or vinyl decals. Does the summa DC4 would be my best bet? If not, what would you recommend and why?
Thanks.
bigben
And do you know how I can calculate an approximative price per square foot for the ink cost?
For example CMYK, CMYK+W+CMYK, spot color, etc.
Is it more expensive than solvent?
Thanks.
bigben
Here is a post on another forum for a price calculator, you the cost for ribbons is higher than ink!
thank you for the link. So if my calculation is right, printing cmyk on regular vinyl cost around 2$/sqft of material and ink? Am I right?
S
Stan B
Guest
solvent may do POOR, faded, semi-opaque 2 layer (white+color) but not 3 (color+white+color). For strong 2 or 3 layer you need something more opaque than solvent - ribbon or UV. After you review summa samples, Roland UV printer may be your best 2nd bet.
signage
Usually you need more than CYMK +w then other side. You usually need a blocking color so it end up being CYMK+W+Gray+W+CYMK. All inks are translucant so you see what is on the other side when using just white.
bigben
Ok, so then does it would me less expensive to print miror on static and "laminate" with a white vinyl using a "regular" printer like a solvent or latex? Does the static material will still hold down?
