Marque Sign Frames
LowcountrySigns
Where can a find a supplier of these frames? I need the black frames and Proveer doesn't supply them...
Plastic Sign Frame (Marquee)
The Marquee sign stand comes in standard white, black, blue, green, and red. A perfect solution when colors are required for the desired affect. * Overall size 26” wide x 41” High * Sign display area 24.1875” x 36.0625” * Easy open handle makes lifting and setup easy * Weight 18 lbs., can be ballasted with 5 lbs. of sand per side (total of 10 lbs) * Custom colors available - minimum quantities apply Marquee Sign Stands have been accesorized with the latest sign display technology.
Thanks for the help!
