Multicam error code
WESTERNSIGNCO.
Hey guys anyone ever had error code 706 Z1 fault drive pop up while setting max depth? Instead of touching off the grounding magnet as it usually does it bottoms out and throws the error code. Any help is greatly appreciated. Using fast start top down method by the way. This is on a Apex 1R
We have tried resetting the machine and homing it after warm up and continues to give us the same message each time.
WESTERNSIGNCO.
Sounds like a broken wire within the probe or worse, a bad motherboard input. If you don't have support from multicam, I'd order a new grounding magnet and see if that fixes it. Otherwise I'd call multicam and ask them...
Nailed it..ended up being a short between the wire and grounding block. Removed the screws only to find the wires had completely backed out from the block. Thank you for the help!
