Mutoh1324 x Error code E075
Dizzy1971
Mutoh 1324X printer, put in a new printhead and new cables, now its throwing an E075 error code, heat temp. Im about to put in a new CR board hoping that will fix it! Anyone else have this issue and fixed it? Im dead in the water until i get this thing fixed!
bil
Hello Dizzy,
Check that the printhead cables are securely connected and that their pins are not damaged, and make sure you have identified the correct connection between the printhead and the CR board.
Attached is the printhead cable connection diagram.
