Need a plotter...prefer MM
tcorn1965
I am looking for a vinyl plotter, needs to be 40" - 42" wide, and have the ability to read registration marks. I know very little about plotters, so I have no preferences for brand. We currently have 2 now, a mimaki CG-160 fx and a graftec 24". I am also open to good used unit. Will this need software? dumb question. What software is recommended?
Thanks in advance all!
Terry
CS-SignSupply
What software are you using now to drive your current cutters? Will this cutter be added to a different workstation, where you may need additional software?
tcorn1965
The other machine uses fine cut. This plotter (cut only) will be on a different workstation. I have Illustrator CS5, is there a plug-in that can be used with that?
Terry
CS-SignSupply
Seeing as you have the Graphtec 24", what about a Graphtec 48" with the Cutting Master Software that allows you to cut direct from Illustrator?
