Omega a sequential numbers
artofacks1
Is there a fast and easy way to set up numbers from 1 to 99 in Omega with out having to type each one. 1 x 1?
Thanks!
Type in #1, then select it, go to repeats, click auto number tab, fill in the blanks. When you type in the #1, make sure the justification, type face, size, etc. is what you want. If you want to include a border, logos, etc., set that all up first including colors and other attributes. Then select everything you want to repeat along with the #1 and go to repeats. The # sign with the 1 tells Composer you are using auto number.
Doug Goodloe
800-232-8018
