PANTONE COLOR ISSUE - ONYX THRIVE AND EPSON
Station51Graphics
Hi all, our shop is running an Epson S80600L with Onyx Thrive v21 as our RIP software.
Just over a month ago, we were printing dead-on Pantone swatches.
Now that the time has come to produce a full set of vehicle graphics, our output colors are different.
Same printer, software, settings, and files, with a completely different result.
See the attached photo (we are printing on reflective vinyl, so the picture is far-off from what the naked eye sees.)
The top swatch is what we want, but the bottom is what we are getting.
The biggest problem: I can't find any issues with the printer, or any settings that changed. What gives? IMG_3599.jpeg
All printers drift over time, especially in mid tones and grays. You need to re-linearize using a spectro to get consistent color over time. That is a fair amount of drift for a month though. If the printer's environment changed a lot in that time it could explain it. Or even if you switched from OEM to 3rd party inks. Maybe you used a different profile for the original?
Station51Graphics
Same environment (73 degree controlled room). The color is consistent (but wrong) on different media.
The only inks we use are the official Epson products through our supplier.
I cannot find any changes within Onyx that would have caused this. Again, running the same file with the same settings now has me this far off!
That sounds like a drift/linearization problem then. What I mean by consistent is, consistent over time, not necessarily between medias. So, while everything is exactly the same, what's changed is the output of your printheads over time which is what linearization fixes. It's something that printer dealers don't often educate people on because they want to sell a turnkey, hit print and walk away experience. The reality is that, in order to hit consistent color over time, you have to linearize periodically. Otherwise, you get color drift like this. If you don't have a spectro, the best you can do to solve this is mess with the CMYK values or play around with the color curves in Onyx.
  • Agree
Reactions: 1 user
