Plotter Info?
SD
We are going to purchase a 24" plotter. Any suggestions on what to buy?....Thanks
ikarasu
2x Cricut explorers right next to each other.
I like how you're an 8 year old member, and this is your first post... ;)
What are you using it for? how much use will it get? Whats your budget?
  • Agree
Reactions: 1 user
Ken M. Klein
I have a Gerber 48” Odyssey plotter with Gerber Drive and optical tracking for long,
accurate cutting and one legal copy of Gerber Omega 3.01 with security dongle. $3,400
SD
Thanks. don't know if I need that big. I'll get back with you if that will work for us......Thanks again for the response.
SD
Don't know why the 8 year thing is relevant, but Thank You for the reply.
ikarasu
I didn't mean offence, just surprised you've been here 8 years and this is your first post - That's some great lurking skills. (Which there is nothing wrong with).
You should provide us with more information though. What will you be cutting? How accurate does it need to be? If you're cutting window tint for a car, it's a lot different than if you're cutting Diamond grade reflective for street signs.
Do you want some cheapo machine that will do OK, or do you want one that will cost 3-4x as much, but last you 10-20 years?
Graphtec, Summa, Roland are all high range ones. You'll be dropping $2-3000 on a 24".
Uscutter sells 28" cutters + a Heat press + 50 FT of vinyl/T-shirt vinyl for $400 - It's good for hobby stuff / if you wont be using the machine more than a couple times a week, and not cutting stuff thats 10 FT long.
Theres a huge range in price and products... it all depends on what you want to do, and what your budget is. Personally I'd spend a couple grand and buy a brand new graphtec.
Again..depends on what your doing. IF you're not cutting DG / thick material, a CE edition will work.
Graphtec CE-6000 Vinyl Cutter
If you're going to be cutting thicker material than vinyl, the FC is best. Graphtec Vinyl Cutter Cutting Plotter
Pippin Decals
I use a titan 2 24" cutter . amazing and accurate.. Ill send a link to my website to show you what i have done with it..
