Need to replace the top decal on this lighted sign cabinet. Top image is the original, bottom image is the new design. Sign size is 72"x52"x .177" It's pushing 10 years old so I believe replacing the entire panel would be wise as there would be a risk of ghosting or am I incorrect in that thinking? The channel letter tracks are glued on. I'm not 100% of which adhesive to use. Located in upper midwest so we have temperature swings here. Also another question about the top decal. I want to print/laminate it. I know you need to let the polycarbonate off gas but I still have run into instances where the vinyl will bubble in the heat and then shrink back when it cools off. Any tips as to why? I've always applied dry? That could be the issue in reading others posts. Or should I use white acrylic, apply the printed translucent decal on the outside. Is there a way to identify if the substrate is poly or acrylic? I'm now overthinking all of it and would appreciate any advise. How would you approach this project.
