DesireeM
Has anyone had the chance to use Avery's translucent cut vinyl since they changed the backing material?
It's now a thinner, clear material.
I'm asking because we've used it twice now on long backlit cuts (One 168" the other 112") and in both cases I did the usual alignment of the material to make sure it was feeding straight and not walking (usually I'll roll out 5-6ft just to be sure) and it was fine. Once I sent the actual cut file though the material started out fine then walked completely off of the end pinch-roller and ruined the whole thing (they both had solid backgrounds so there was no salvaging anything).
I've never had this issue before. I always make sure the material is not going to walk. I'm wondering if it's due to this new backing material. It's much thinner. The material is harder to handle because it's so flimsy now and it seems smoother....Perhaps my pinch rollers just can't grip it properly. I use an old Roland Camm-1 Pro cutter 48".
I was able to cut both jobs by eliminating the outer border of the cut. That way it didn't feed the full length of the sign border before cutting the stuff in the middle. That seemed to help. I'd like to try changing the feed speed as well but I can't really sacrifice that much material just to test it out.
Anyone had a similar experience?
