Craig Keller
Ok we print a lot of general docs using a epson 4c tank printer. But its hard to hit teal colors on it. As well as some purples. We use this to print out mostly samples to let them see the layout in order to approve not the color. But in some cases we try to use it for final product on like card stock but struggle with these colors a lot. I have a oki laser printer that we print some of this on using a coated paper. Same thing the teals are a challenge on it but not as bad you can usually get it pretty close. Its time to replace the epson 4c tank printer is there a better choice? Any standard 6c tank printers other then epson 6c photo tank printers? A laser that would work for both hitting the teals and purples that would get the volumn of the old tank printer?
I also have a epson 6c tank printer in the back that can hit the teals but will not print on coated papers.
