simon haysom
Simon
Might seem like a bit of a strange question. Is there any real disadvantage in having a printer that is wider than you really require?
Apart from the obvious one. (It takes up more room and more cost installing.)
I have the opportunity of purchasing a 1600mm wide Mamaki at a very good price. Up to now I have been using an old Mutoh VJ1324 (on its last legs). This has been more than wide enough for my needs.
I am tempted by the Mamaki (it's cheaper than the smaller printers around). I know about all the things to check for when purchasing a second-hand solvent printer.
Will it use significantly more ink with its cleaning cycles than a smaller printer?
Your thoughts?
Your thoughts?
