Printing window stickers
Riada
Hi. I’m wondering if anyone knows how to print on adhesive side of vinyl for use as window stickers? We have an enquiry for double sided stickers 400mm diameter.
we have been asked a few times to price for this and I haven’t been able to find out how they’re printed. We are just about to install a Mimaki CJV330-160 next week.
we’re based in the UK BTW
White Haus
Not a Newbie
Technically, you can't print on the adhesive side of the vinyl. Assuming that you don't have Latex/UV white ink capabilities, I'd suggest the following:
-Reverse print first image on clear vinyl
-Back first image with white vinyl (can be any cheap calendared cut vinyl, Avery 750, Oracal 651)
-Print second image on white vinyl with grey adhesive
-Laminate two parts together
-Cut to shape
-Ship to customer and collect the cheque
Ideally this works best when registration isn't super critical, but you can get it pretty damn close by ensuring you print a bounding box that will be exactly the same with both files/images.
Use that to register one to the other, with a lightbox or flashlight looking through the material.
Hope that all makes sense. Only have an ounce of coffee in the system and still waking up.
  • Agree
Reactions: 3 users
FireSprint.com
Wholesale Signs, Stickers, Banners-Free Shipping
We run them on clear media. Mirror the ink then flood white behind them.
If you don’t want to mess with them, we offer them wholesale at FireSprint:
  • Agree
Reactions: 1 users
1upgraphics55
The others are correct - you print the graphic mirrored/reversed on clear vinyl and then print with a white ink backer (which is how we produce them on our HP Latex 800W) or, in the case that you do not have white ink printing capabilities, you can 'laminate' them with white vinyl. Just remember to leave the cutter registration marks UNCOVERED by the white vinyl backer so that your plotter is able to read them. :)
We also produce these stickers in-house... just not sure how expensive the shipping to the UK will be.
You're welcome to request a quote through our website1UpGraphics.com and we're also in the works of building a custom sticker website, Stick1Up.com, which will be up-and-running within the next week or so.
