Need Help Printing with a Roland TrueVis and would like to cut from a Graphtec
SIGNDZYN
Would like to know if we can Print decals with SignLab 10 than to Versaworks 6 than to a Roland Truevis and laminate and contour cut the decals with a Graphtec FC 8000-160 what are the steps if can be done !!
Attila Nagy
If you use CutingMaster4 you can create the cutline, registration and barcode in Illustrator and Print wherever you want.
CanuckSigns
If you are running Versaworks, it only supports Roland Cutters, however Graphtec has a plugin for Illustrator & Coreldraw to put the correct graphtec marks directly in the print file, however you would need to design your files with your multiples in your design program, so rather than design 1 decal and multiplying it in versaworks to get 500 decals, you need to create a print file with 500 decals on it.
