re cut not lining up
petepaz
versa camm sp300v
ran a job about 10 sheets 5 large decals on each
laminated and cut
relized afeter the blade was not deep enough
(i know test cut i screwed up)
but went back to cut again and they are not lining up
if the cutter is supposed to go by the markes shouldn't it cut the same every time
it is off about 1/8 or so
and part of the decal has a cut out that lines up on a control panel
Former member
Do a print cut calibration. Scroll through the menu till you find it.
I usually do the "auto" calibration. I try to do this once a week or so. Overkill maybe, but you'll think different after you ruin a couple hundred decals.
Anyway, give it a try, this will get your machine back into alignment.
petepaz
thanks i will give all these a try
i think what the problem was
that i was cutting laminated vinyl
then switched job and was cutting laminated brushed silver (needs to be a little deeper) and forgot to change the depth
