Dukenukem117
I need a tape that's ideally 0.75" but can be as wide as 1" to apply over a mesh printed with latex. Everything I've tried so far eventually peels off after a few days. Anyone have suggestions?
			3M VHB High Dollar or mactac rebel H Adhesive tape. We use both all the time off of our HP LX300. You might rn into an issue with the mesh becuase of the rough uneven surface and the limited energy of the adhesion because of the holes. We never tape mesh. What are you trying to accomplish with the tape? Are taping edges on a banner or trying to stick it to something (like a window?) If doing banners, buy a used sewing machine or welder. If using black backed banner mesh on window, use a window cling adhesive on the face like Drytac Windowtac. Hope this helps.I need a tape that's ideally 0.75" but can be as wide as 1" to apply over a mesh printed with latex. Everything I've tried so far eventually peels off after a few days. Anyone have suggestions?
We have a velcro tape on the opposite side and I wanted to block the holes so that air doesn't degrade the adhesive over time. Sort of like sealing it from both sides. The velcro holds pretty well cause it has an acrylic adhesive, but we've noticed that after a year or so it starts to degrade from exposure to the air. 3M is kinda pricey unfortunately. I tried strapping tape since its coated to a PP surface, so I thought that it would hold. But guess not.3M VHB High Dollar or mactac rebel H Adhesive tape. We use both all the time off of our HP LX300. You might rn into an issue with the mesh becuase of the rough uneven surface and the limited energy of the adhesion because of the holes. We never tape mesh. What are you trying to accomplish with the tape? Are taping edges on a banner or trying to stick it to something (like a window?) If doing banners, buy a used sewing machine or welder. If using black backed banner mesh on window, use a window cling adhesive on the face like Drytac Windowtac. Hope this helps.
