Need Help Roland RF-640 : ink leaking problem
harperwenson
The Roland rf-640 at my workplace is having an ink leak issue. Specifically, the cyan ink is leaking. I can see the ink pooling under the gold plate of the printhead. Does anyone know what's wrong with the machine and how to fix it? IMG_20250917_141327.jpg
damonCA21
If it is leaking through the head most likely a damper or manifold problem. It could also be the head has failed internally.
Move the head to the side over the vinyl and clean the surface and see if more ink comes out. If it doesnt then check your captop is draining properly as this can also cause ink on the head
