Roland RT-640 Dye Sub Printer: test print erratic carriage movement, no prints after faulty damper
mrn4545
I'd like to understand what's amiss with our Roland RT-640 dye sublimation printer.
One color was dripping uncontrollably. We then replaced the damper. A faulty OEM damper brought dye onto the print head cables. We replaced the cables, print head, cap top, and dampers. We changed the head rank, did a powerful cleaning, choke cleaning, and everything else as outlined in the service manual.
After replacing the OEM print head, cables, OEM cap top, OEM dampers, and OEM felt/rubber wipers, we're seeing erratic movements with test prints, and no depositing of dye. Regular prints result in no dye being printed.
I then noticed some dye on the side of the print carriage board. It's stained on the side of the board. I see no dye on the rest of the board.
Could this dye be causing the erratic movement? I have a video to share if it'd help.
Would a fault at the carriage board due to the dye also ruin the new print head?
dtfonestop
I'd stop printing on it for now. If dye got onto the carriage board, keep it powered off until that's cleaned and checked, because a short on the head drive side can take out a new head.
Unplug it, pull the carriage board, and look at both sides and every connector under a light. Dye residue, green or white crust on the pins, or any dark spots near the head connectors are what you're looking for. Clean it with isopropyl and a soft brush and let it dry completely before it goes back. Check the ends of the new head cables too, since the old ones may have carried dye into the sockets.
For the erratic movement, look at the linear encoder strip. A leaking damper often splatters it, and a dirty strip will make the carriage hunt and stutter. Wipe it gently with a lint-free cloth and a little isopropyl, and check the encoder sensor on the carriage while you're in there.
For no ink at all, make sure the new dampers actually filled during the ink fill. Empty dampers will look exactly like a dead head.
If the board shows damage, I'd have it tested or replaced before you connect the new head again. Is it throwing any error code, or just moving wrong?
