Worldwidedigital
So I have had this problem before and can't for the life of me figure out how I reset it before. I have two machines so I can cross check. We had a Network meltdown and had to reconfigure the entire networks static IP Addresses. So here is the problem. Used the Intercon tool to reset the IP address and it takes it and goes into a BIOS mode. Close the Intercon window and ping it see the ip address with a patch cable hooked in. Launch the Roland Firmware updater and it can't see the IP address. I know this is an issue with the network card because I switch it to the other printer and same problem. Reset the network card and re-entered the IP address and same issue. I can see it and ping it but the Intercon tool is in Bios mode and needs a *.bin file to upload the firmware. I have called a Roland tech and they have never heard of the file and they are looking into it. Sooooo here I am needing this firmware file for the Intercon tool *.bin to flash the Bios on the network card.
I know it's isolated to the network card because I moved it from another machine.
