Router Bit Suggestions
Think713
Hey everyone,
So we run an older colex router. I believe its an SX series... We use a er25 collet with a 6-5 shank diameter. The bits we get for routing aluminum and ACM are constantly chipping. Even for carbide bits I think this is a bit too frequent. All of the colex bits from their site seem to be single flutes, but we are looking at endmill bits for cleaner and more consistent cuts. Is this something we should try or do any of you have some solid suggestions for bits that will get through more than like 2 (4x8) before the bit starts fraying edges.
https://toolstoday.com/v-15030-48430-k.html. I found this bit here, and I think this might be a good option, but again looking for experienced suggestions.
We mostly cut: Acrylic, ACM, Poly Carb, PVC, Styrene, and Coro.
John Miller
Be sure you have your rpm and ipm settings correct, I've never had a single flute bit chip. Post what your settings are and the material thickness, type & number of passes. With that info people will be able to give you advice.
packratsigns
I've only used Belin Bits for over 25 years
The Amana brand is good but I have''nt used them.
13317 - 1/8 - for acrylic
33317 - 1/8" - for aluminum
33476 - 3/16" - aluminum
13476 - 3/16" - acrylic
33635 - 3/16" - aluminum
13635 - 3/16" - acrylic
Send me a private message if you want more info.
