Wes Phifer
I need some letters that will be used inside one day. Cut out 1/2" to 1" thick. Any suggestions? Suppliers?
I need 72 - 6" letters cut. For easier install a foam would be great. Can anybody do that for me.
Slap some vinyl on some pink or blue insulfoam, cutout on a bandsaw or jigsaw and spray edges with desired color of latex craft spray paint and call it good. Couple hours tops to produce.
Exactly what I was thinking, unless they are all the same letter which I highly doubt.72 letters in 2 hours would be 1.72 minutes per letter. I see it taking closer to 6 or 7 minutes per letter. More like 7 or 8 hours for the job.
Maybe a couple hours ... Last time I did this ... took me about an hour to produce 20 characters after I made my stencil. maybe 20 minutes to paint them if you use spray paint.
I have hundreds of hours on a bandsaw. (maybe thousands) The bandsaw would take way too long because you would have to keep cutting and welding the blade back together for the insides of letters like O's and A's. A scroll saw would be better as it has a removable blade system for just this purpose. A jigsaw would work if you had a really good one that didn't suffer from blade skewing.Okay, A couple hours is a bit of a stretch depending on the size. Dimensional cutout letters happens to be one of my forte's so it's not fair for me to expect everyone to be able to crank them out at that rate. Regardless....I stand by my suggestion. It's the fastest and most cost effective for a project like this, if one has any reasonable level of comfort and skill with a bandsaw or jigsaw. If they don't...farm the cutting out to someone else who does.
