Suggestions Tips to maximize the lifespan of a vinyl banner
One of my things is to spray it with SEM Color Coat #13003 clear vinyl coating. This is vinyl marine-grade product that helps with UV protection and makes the banner more scratch resistant.
McDonald Signs
McDonald Signs & Graphics
Pole pockets top and bottom with electrical conduit inside pole pockets. You can rivet or use small screws thru banner into conduit to keep it tight. then use bungee cords or bungee balls for each end of the banner to hold it tight to posts.
You can find alot of uses for these Bungee Balls for tarps. Holding rolled up extension cords together or securing other things. You wrap the loop around what you want or thread the loop thru a banner grommet and then the ball goes thru the loop to hold it tight. Works good for holding down tarps too which is what they are made for. And they're cheap.
  • Agree
Reactions: 1 user
kcollinsdesign
Old member
I swear I feel like I'm coming off heavy but don't mean to, so no offense meant.
If you cannot pull a permit, you should not be quoting the work. Very few Licensed Sign Contractors will pull a permit for anyone but themselves. If they do just about any qualified shop will beat your bid. Here in Florida a simple face change does not require a permit (yet) but I'm pretty sure no insurance company will write you a policy if your not licensed. Catch 22. That being said I've done tons of this stuff over the years and didn't pull permits for simple stuff, but we live in an area where the inspectors don't work very hard at their jobs, lol.
Pulling permits for others is a good way to lose both your license and your insurance.
  • Agree
Reactions: 1 user
