Hey everyone i own a ucjv300 that had lus 200 inks, ccmm ykwhitewhite. I switched to a dual cmyk setup because white ink is difficult to maintain.
I've gone and changed to the lus175 ink set in the menu. I've installed new hoses and disconnected the old recirculating pump for the whites and made channel 7,8 have the same hose routes the cmyk does. Brand new lines, new valves by the bottles, flushed the bottle holder best I could.
Now I had white clogs in the clip fittings, hoses that I've cleaned. My idea is running some flushing solution through an old subtank into the white head to see if itll help. Also thought about doing a reverse draw, submerging the head increasing solution and drawing up with a syringe.
It was down over a month so may e ill be lucky but would appreciate any tips. I've been letting the printhead sit in a filled cap tops of thr cleaning solution 07 to help start the progress. Doing 24hr or longer
