UJF-7151 plus "Supply Ink" error on startup
Hey guys,
Getting a constant "Supply Ink" error on startup.
The machine was prepped for storage, so it has conditioner in the line instead of LH100 Primer. I've already put in a new pump and main filter, but the error pops up every time on cold boot or fresh start.
What usually triggers a persistent Supply Ink error when pump and filter are already ruled out? Sensors, sub-tank floats, valves?
Any ideas would be appreciated, thanks!
netsol
i wonder if it requires an "initial ink up" procedure after WHATEVER sort of procedure was used to prep it for storage
It should show which ink isn't getting supply in that error. Which one does it show? The supply ink error just means the sub tank isn't filling for some reason.
Smoke_Jaguar
Mimaki's worst printer hands down, badically have to start throwing pumps and valves at it until it works for a week or two. Then another channel will break.
  • Angry
Reactions: 1 user
The machine is running normally as in not needing initial fill ups or anything, the line with supply ink error is the primer line like i said,
I already replaced a new diaphragm pump for that line, and filter.
But i find it weird that the machine doesn't even go through the process of cleaning or filling up the sub-tank and then detect the error, its instantaneous when starting it.
Smoke_Jaguar
PR200 primer has a really nasty habit of gunking up in the lines. You might be able to flush the system with a liter of flush 7 and get it going. The subtanks are in 2 sections per head, so it's a unique setup compared to most gravity fed heads since it is a thru-circulation system. Some of the valves can be disassembled and cleaned, but the primer is going to be the real wildcard as it can cause seals to swell more so than most inks. Thankfully, the heads tend to be pretty robust.
I got flush to flow through the lines (at least supply as i cant check return with AGEING in #test menu), and even with flow of liquid to the subtank, still same issue. In #test the sensors for primer head are both reading low but reading something so i am really lost here with this machine. confusing stuff
