I know it is typical form for people to post negative replies, but in the case of DCS and the 4x8 UV flatbed, it is all I have.
We purchased the UV-84DTS for the same reason it appeals to many that look into it. We wanted to produce more ADA signage, faster. By all regards, the DCS is like adding more hands to your ADA team. However, we were given a much different spec than what we have been able to output. Almost a year after we purchased the machine, we still haven't managed a full bed of braille and tactile (only; no flat print) still takes us over 3 hours to print. In a average 8-hour shift, you can send 2 full sheets of material, allowing for substrate changeover, alignment on table (no alignment pegs, have to use the engraved mm table guide) and the (IMO) ridiculous file setup process.
Let's start from the beginning. The provided Color Byte software is another facelift on the same old
sign layout software. Lots of functionality that comes with no explanation. However, returning DCS customers will likely feel at home as I believe this is the same software used across their product line (I'm new to DCS products so please check into that if interested {lazy writing, I know...I'm sorry}). I'm not a fan of opening AI files in other vector layout software just so I can access the RIP. With Color Byte, I have been told there is no real option around it because of the braille and tactile building system). My process is now taking in-house built AI files, opening them in Color Byte, sending them to Color Byte RIP, which then RIPs to the DCS Control software. In all of those transitions, I can only hope that nothing in my files has changed and all will produce with the intended result...yikes.
Credit where credit is due, this product launched during a global pandemic. I don't think anyone was as ready as they thought. DCS support and techs have been patient (if not a bit overconfident sometimes) but have usually helped me get to my nearly-desired product. We have had 4 service visits, replaced 3 parts (only one of which was a "consumable") and still have a mountain of questions. Currently, it is mostly down due to calibration issues. In fair play to DCS, this one may have been User Error!
Now, the good news. 5 G5 heads, comparatively noiseless carriage motion, no capping station, no vacuums (except for the bed, of course) and a DAMN SMART white ink cycling system.
G5 heads produce beautiful images with controllable dot-gain and seemingly easier to maintain. We get fewer lost nozzles that our Mimaki, the ones we lose are reclaimed quickly with DCS' purge and wipe system. 5 heads with 7 head stations, including 2 CL heads for ADA builds, a 2-channel white head, YK, and CM.
The dual-vacuum bed fully encloses the vacuum motor, cutting the noise down drastically. However, check your acoustics before installing as we were overwhelmed by the sound when in a tight space with no carpet.
Ditching the capping station is an intriguing step. Automated maintenance is a wonderful feature when you have it, but I find manual cleaning is faster and allows for on-the-fly cleaning. I will say that the waste station "tray" feels like a last-minute thought. I mean, its just a large funnel with a hole and 12 inches of hose. Maybe it's a petty dig at DCS but, come one...I just put this carpet in.
Sorry, this is supposed to be the good part of the review.
Lastly, there are no SHOP VACS to replace like in the HP Scitex models. The white ink recovery/recycling system may or may not be an original concept (my first time working with it) but I'm happy to not have to shake another bottle/box/bag of white ink. The system has a supply pump, running through heater areas to keep the thick ink flowing as easy as it can. This ink cycles through small subtasks in the carriage head and then returning it to the main tank so as not to overcook the ink.
Bottom line, this is the first operating line for this product. As a rep from Cannon recently advised, wait for the 3rd generation. I think DCS will really have better understanding of the technology on a larger format.
I hope this helps. I have not written a review in a long time.
(My background:
Sign building for 23 years; printing for 15 of those. The UV-84DTS is my first DCS experience.)
