Artistic-Brief3072
Which UV flatbed printers can reliably print raised texture of 2 mm or more? If you've done this in production, how has it worked for you, and has the raised ink held up over time?
The Fluid Color Braille Monster is a sweet setup and I am fairly confident it will do 2mm. They take a three row machine and put three heads of clear varnish in the first row, 2 heads of white in the 2nd row, and then CMYK. We printed a 4x8 print of raised ink (it was a map of a lake) and it only took 27 minutes. I'm more than happy to send you some pricing or set up a virtual demo for you (or an in person demo). I'm out in LA in two weeks in case you are in S. Cal.Which UV flatbed printers can reliably print raised texture of 2 mm or more? If you've done this in production, how has it worked for you, and has the raised ink held up over time?
How much are you looking to spend?Which UV flatbed printers can reliably print raised texture of 2 mm or more? If you've done this in production, how has it worked for you, and has the raised ink held up over time?
I looked at all of the flatbeds at the Print United show and none of the major brands had a large flatbed that did good raised ink. Some had small models, but we wanted to be able to print both 5x10 and raised, so we went with FluidColor.Does anyone have experience with Roland, Mimaki, Mutoh or other mainstream brands that can reliably achieve relief heights of 2 mm or more?
