blufftonsignguy
I am in need of some assistance. I have a Roland VG-540I that is having problems with cutting. My latest is pressure. It is like it changes itself every cut. I have put a new 60 degree blade in, and adjusted the height accordingly. I set it to 70 grams of force to cut through laminate and vinyl. I send it to cut and the lines are pretty accurate but with the force it barley scores the laminate. The last run I had I adjusted the blade length out a little and added a little more force. On one cut line (multiple cuts in one run), it cut through the backing paper and everything at the top of the sign and down the side it got to the point of scoring the laminate again.
This has been really frustrating because it was fixed under warranty last year because of this problem (which was never truly fixed) and now I am having the exact same problem again. Anyone have any ideas?
TIA
TIA
