Hi!
Before you scroll away because this printer is known to be a headache by itself, I am simply looking for input from anyone who has had a similar issue on any printer with 10 ink channels!
The issue: The last most right nozzle(s) of my printer refuses to print on its nozzle test unless I manually syringe ink through the capping station.
The methods: I do power cleanings, normal cleanings, I even wipe the print head with monomer at times, nothing but sheer force will get these two white channels going.
I know the print head is not siezed because I can get ink flow through the print head and capping station with a syringe. But if I do a cleaning after priming this way, I lose the nozzles again.
I have cleaned out and refilled the two offending ink tanks,.
I have replaced all the white ink circulation pumps.
I have replaced the print head.
I have replaced the ink lines.
I have replaced the capping station.
I even just calibrated the print head and uv lamp height with a jig I purchased from the manufacturer.
Ink set up: white1, white 2, clear 1, yellow, magenta, cyan, black, clear 2, white 3, white 4. the white 3 and white 4 are the constantly missing nozzles.
Sad to say it is a DCS7200z. But again, I am looking for any input from anyone on how to revive nozzles on a print head that is not shot.
Thank you in advance!
