White spots problem on print
vlami436
Dear,
I have ValueJet 1614 and recently, i received the same problem with white spots (most know like fisheye). Can someone define the core of this problem. Is it the dust in the air (or in the working place where printer exist), heater problem, ink problem or low paper quality.
For me is very important to find solution on this issue because i have very good machine and noizzel check is excellent so i should have the best print in the world but with this issue i have the worst print full of white spots allover the vinyl.
Thanks in advance.
Sincerely
gregwallace
Are you seeing fisheyes or just a blotchy looking print? Is it throughout the whole print relative to ink coverage or is it just a few here and there in a random placement?
SlightlyChilled
Is you vinyl clean? Is your heaters set up right? are you using 3 party ink. Is you room humid??? there are lots of things... it is not just hit the red button and make money
mark in tx
Could be any number of issues, dust, bad vinyl, or static electricity.
Static is a common Mutoh problem most people don't even know about or consider.
