  • [URL unfurl="true"]https://jaysprinters.com/products/6090-uv-3-head-printer?sca_ref=6275292.kd5SR5a8XC[/URL]
Signlab 9.1 copy and paste
alpha1978
Hi, all. Has anyone come across this problem and know of a fix?
The copy/cut and paste in signlab has started to take forever to paste into another instance of signlab.
I can export and import but it alters the file and turns font to vectors. Doesn't matter what options are ticked or if its an ai, pdf etc.
I really just want to use the copy and paste function which until recently worked fine.
jjh781
I had a problem where it wouldn't paste at all. Just stopped working one day. Anything I copied or cut wouldn't paste in at all. I believe I had to reinstall the software to get it to work. I also was using signlab 9.1 cut & print
Broome Signs
hi
from memory it is a windows problem, to do with the memory page file size,
think we set it to min 195, max 1500mb
hop it helps
alpha1978
Thanks for the replies, I will have a look at the page file size and if that doesn't work I will go for the reinstall.
