myront
CorelDRAW is best
Too all, I will continue to use Corel as my "go to" but we also must have illustrator and since most jobs require some knowledge I just thought I'd at least try and learn a bit more. I've had illustrator for over 25 and many times tried to learn it but end up frustrated. I thought if only I could pick some brains and be showed some basic things I'd like it better or at least get along a little better.
Sure I'll point out some major differences between the two and probably upset many but I'm asking for constructive criticism without the negativity. Believe me, I am just as frustrated trying to teach corel to the adobe trained.
Some more points
illustrator files are typically twice the file size than corel. I rarely have a corel wrap file at full scale, another subject altogether, over 600MB. Same file built in illustrator would be 1.5GB
Am I missing something? In illy you must select a size before you even begin designing. Since 90% of our jobs are landscape "Broad Sheet", I have my corel set up to automatically start there. Actually I've gone beyond that and have a customized macro to start a new design that has a label with the current date & artist's name. Also has our standard disclaimer paragraph explaining the importance of proofing.
Customizing the workspace is much harder in illy. And keyboard shortcuts are limited to "F keys"? I have many customized keyboard shortcuts in corel assigned to various macros (only 1 uses the F1 key). hit F1 and outlook opens a mail template for proofing.
I would like to know some alternative ways to duplicate a shape. I only know the holding alt method. In corel I can think of 5 different ways. My go to is drag a shape and before letting go right click. Can use ctrl to constrain.
Can I flip a shape with the mouse or keyboard command?
Some more points
