airborneassault
Good evening all! Our S80 lost all nozzles in the Lc/Lm #2 Head. Went from perfect nozzle check to absolutely nothing. I've run 3 each of the medium cleaning for the affected nozzles and the heavy cleaning as well as manual head cleaning which showed no issues and still no sign of Lc/Lm
I filled the cap tops with solution and tried to "park" the head but I'm not familiar enough with this solvent machine to keep the solution in the caps vs having it flushed directly to the waste ink tank. Our old roland I could clamp the return lines and essentially soak the heads overnight to recover nozzles.
Any suggestions? Thanks in advance
