FC7000-100 error message
bradsc1954
I have an FC7000 that I recently got. I am the process of trying to set it up. When I send a cutting job from Illustrator using cutting master 2. I get error 1, instruction not recognized.
What am I doing wrong. Any help would be appreciated.
Brad
Sounds like you are trying to send in the wrong language. Either that or you are trying to send without a driver installed. Language can be changed via the plotters interface. Menu> I/F>Command> Change Language and see if this helps.
tbullo
Superunknown
Agree, sounds like you need to put plotter into gp-gl. No media in, hit initial menu, interface, command then select gp-gl.
Yeah, the person you bought it from was probably using Flexi or some other RIP that uses a different language. When using the Graphtec plug-in it has to be setup for GP-GL. Also, on another note, that machine is no longer supported and very hard to get parts for. Hopefully you didn't pay too much for it.
