Gerber envision won’t cut through vinyl
Will308decals
Hi, I have a gerber envision 375 and I have cut very thin vinyl with it and it works fine with that. But I want to make football helmet decals which has a 21 mil thick vinyl and I have the little blade stuck out as far as it will go and the force turned up all the way on my envision plotter. Does anyone know what the problem is? Do I need a new blade? I am unsure on what to do. Thanks!
Fred Weiss
You will benefit from using a 60 degree blade for the thicker material. I would also recommend if you are going to be going back and forth between thick and thin that you invest in a second blade holder. Getting the depth of a blade set correctly is time consuming and having a second blade holder all set up eliminates the wasted time.
Jburns
here are my settings for heavy lam and convex three passes what fred said also
Fred Weiss
Those are his advanced plotter settings. In GSPPLot enter F7 and then click the Settings Button for your plotter. S = Speed, G = Acceleration, P = Pressure or Force, and CR = Sharp Corners.
Billct2
and you can set the plotter to go back to the start position after cutting in case it needs another pass.
Billct2
here are the tools in 5.0, I think they were the same in 2.6
Will308decals
What vinyl brand do you use for your heavy laminate? I make football helmet decals and my 21 mil will not form or shape the roundness of my helmets and they bubble up
