Need Help HELP E074 err Current Cr and Bands
wayaman
Waya
hello my friends i know this is an old thread, but i have the same problem with my vj 1204, check the image, i buy a new print head whit a flat cables new and one kit of maintenance, i try print but E074 err Current Cr and the carriage stop in the middle of the printer, and later of reset the printer send a new print and i have this...
See this
print and after 11 pass print a band of black combined just like that
please help me... i don't know what happening.
Try taking the long top cover off of the machine and run a print that way. If it works, your CR cables need to be changed or just run without the cover on as long as you can.
Production BSKL
See this
Please try this below,
E074 CR2 overcurrent Overload condition in CR motor (Yaxis)
Overload condition in CR motor (Yaxis) during printer operation
Check item
1. Check error history from “Check2: Test” - "Test7: Record" - “Record2: Error” of self-diagnosis function.
2. Set the number of endurance running cycles to 50 or more from “Check10: Endurance” of "Life2: PF Motor" of self-diagnosis function, and check if "X motor error" occurs.
3. Check "Encoder: PF" from "Test5: Encoder" of “Check2: Test” of self-diagnosis function.
4. Check if Main Power Board normally supplies DC24V.
5. PF motor assembly may be defective.
6. Main board assembly may be defective.
7. Check if T fence is contaminated or worn out.
8. Check "CR Encoder" from "Test5: Encoder" of “Check2: Test” of self-diagnosis function.
9. Main board assembly may be damaged.
Action
• If grease or dust collect: Wipe fence with a dry cloth.
• If ink deposit presents: Wipe it off with cloth dampened with neutral detergent.
• If contamination or deposit is too heavy: Replace T fence.
a) If NG: Check following cable connection.
• CR board assembly connector J207
b) Replace following parts.
• T fence
• CR motor assembly
• CR board assembly
• CR cable
• Replace main board assembly
wayaman
Waya
I try this, like you recommend and still have problem... print and every 11 pass or less send a error, print a band of black, but if i send a test like a bid adjust print well, and sometimes the carriage stop in the middle of the printer.
wayaman
Waya
Check item
Action
• T fence
• CR motor assembly
• CR board assembly
• CR cable
I will check this, but i don't know if maybe and upgrade of the firmware printer help?
AaronSSsignsKC
o74 error can be a lot of things, i would start by looking into the page feed motor and disc sensor . We kept getting a lot of the same error and similar results a few years back and cleaned the the page feed encoder and it seemed to help for some time eventually we had to replace the whole motor. Good luck
wayaman
Waya
Thanks but i replace the t fence or encoder strip and now only have this problem on bad print or band of black in the image
