serviceSigns
I have a large decal order for a very important customer and I'm having a problem
The decals are printed on 3 mil PrismJET 203 as a sheet of around 4.5' & laminated with 3 mil PrismJET 100. I'm cutting the decals with a Vinyl Express Q54 and the problem is that the contour cut isn't matching up. Sometimes it will start out great but gets off
by a few millimeters or more towards the middle of the sheet. Sometimes it off right away. I have the rollers set on the middle setting because the material is so thick.
Is there something I can do to make this work better or is it something that can't be perfect? Normally if the contour is off by a few millimeters it doesn't matter because my decals usually have a white background or a solid bleed. These have a black stroke around the decal that bleeds off the edge so you can definitely tell that one edge has a thicker stroke than the other.
I think I am getting them close enough to make the customer happy but I'm curious if it could be better. I want them perfect![Cool :cool: :cool:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![Brickwall :banghead: :banghead:](https://signs101.com/images/smilies-orig/standard/brickwall.gif)
