Plugged lines on XC 540
shooter
I had been having some banding problems when printing. after doing the test print, I noticed approximately 3 heads were hardly putting out any Ink. I have performed a manual clean, and the extreme clean on all ABC options. Wow does that dump a lot of Ink. After performing the test print they still don't work.
Any suggestions? Of course this is the week that work has picked up and I have deadlines to meet.
shooter
Here is what the test print looked like after performing a manual cleanand the powerful clean. Am I interpreting this correctly that the machine has three plugged lines? I am using the Roland Ink cartridges.
SE SignSupply
Most likely you do not have clogged ink lines. Could be any of a number of problems; blown head fuse, clogged damper, clogged nozzles, etc...
mgliss
I would suggest printing solid bars of cmyk. A lot of times this flushes out any crap that might be clogging lines of printheads.
shooter
I worked with Roland technical support. I replaced all six of my cap tops and had to manually prime some lines with a syringe. I also replaced the wiper blades and have three damper controls here on backup. Although the wait time was rather lengthy, what a refreshing change in technical support. My last experience with tech support was with Gerber and if I recall correctly I had to pay them just to get in line to talk to someone.
My machine is almost 3 years old. Unfortunately, I neglected to perform a standard routine maintenance. I probably only cleaned the tops two or three times total. :doh: It is good to have the machine up and running again. It is also nice to have the knowledge I gained on servicing my machine.
Thanks for all of your help.
synergy_jim
i am going with bad alignment with the caps... run a medium clean and when you hear the pumps kick on, wiggle the printhead carriage left and right repeatedly.... this may be an easy fix.
