Where can i find the Port Settings ?The program can not find the printer port.
Check the port of your printer in your printer's software.
Hi, again ..
i also got some Problems with the Connection.
Sometimes it works sometimes he break the print.
See the Picture.
View attachment 136563 View attachment 136564 View attachment 136560 View attachment 136561 View attachment 136562
Last Print - Versaworks say Printing... and my VP-540 now progressing ...
but he still not print.
why does the printer stop differently?
Hi, again ..
See the Picture.
If all else fails, buy a new board and install it for $3,000-$5,000.Hello Essty,
Thank you for reaching out for assistance. Have you tried reaching out to your selling/servicing dealer? Typically these issue are due to connection. So, here are some steps to take to help resolve this issue.
1 - verify that your computer is not falling asleep.
To disable automatic Sleep on Windows 10:
2 - Ensure that your network is not the issue. Please connect your the print to your computer directly. Then change your IP addresses on your computer and printer to perform a direction connection.
- Open up Power Options in the Control Panel. In Windows 10 you can get there from right clicking on the start menu and going to Power Options.
- Click change plan settings next to your current power plan.
- Change "Put the computer to sleep" to never.
- Click "Save Changes"
Video on how to setup the network directly. - produced by Roland DGA
3 - Change Computers and Cables to ensure this issue is not with the printer
If all else fails. You will need to get a hold of your selling/servicing dealer for support. This could be an issue with your printer.
It appears from your post, you are in Germany. Have you contacted Roland in your location? Please see link below:
https://www.rolanddg.de/de-de?region=b0d5473e-1356-4d9d-ad78-30c8736c647c
I am confident they will be able to assist.
I hope this helps.
Roland Technical Support
Roland DGA CORP
Thanks I have the same problem now my machine will not even turn on. I took the main board out and it looks like new no hot spots.Hello my friend.
This is a common issue with VP series.. I really tried to find the solutionThe problem is ethernet connection chip on the board. You need to find a tech guy who can repair boards and replace a new Realtek ethernet chip. It costs around 200-300 USD. Otherwise you should change the mainboard. This not about modem, cable, ip issues etc...
Ugur A.
Post in thread 'Network chip Roland VP540'Hi, again ..
See the Picture.
