S3T160 FlexCut Issues
Hello everyone.
I got a Summa S3T160 a few months back. Finally getting around to getting it into our daily workflow.
Lets say I have a sticker job to cut out and its 20 circles, side by side. My flex cut feature cuts out 1/4 or 1/2 of every circle down the entire row, then goes back and finishes the rest instead of just completing each circle at one time.
Anyone know how to correct this? Currently using Summa Gosign on Windows. I would like the machine to finish each sticker and move on, its taking much longer to cut out and sometimes leaves tabs if it doesnt meet back up exactly where it was.
balstestrat
Problem Solver
You can maybe check if the output macro has some sorting options. I think even the cutter has some options on the front panel.
The Cutter Control module has
Paneling: OFF
Panel Size: 50cm
Sorting Vectors: Off
(Options for Sorting is Off, Directional, Start Point)
I tried all 3, with no change to completing the shape.
Saturn
Aging Member
Depending on how large your circles are, if it's an adhesive vinyl you can probably skip the FlexCut and just do one or two "regular" cuts instead. FlexCut can lead to a lot of issues, and doesn't generally give better results for general stickers.
With regular cuts the adhesive keeps the sticker from falling out prematurely (when you have things set up well), but still cut completely through and easy to pop out on a work table.
FlexCut cuts similarly to having Sorting Vectors set to Directional, but there's no way to force FlexCut not to do otherwise. It would be a huge perk/upgrade if they made a toggle for that when using FlexCut. Can be good for rectangles, but not much else—maybe really big stuff on paper or non-adhesives.
For "stickers" I think FlexCut is really oversold, and more of a negative than a positive. In most cases the quality of the finished product will suffer enormously using it, as well as the speed.
Do some testing with one and two "regular" cuts and you might be pleasantly surprised.
jerry369
Hello everyone.
You can increase FlexCut panel size
GoSign automatically turns on FlexCut panelling. S3 firmware uses 2 different panelling sizes, one for Flexcut and one for all the rest.
Flexcut panelling size can be set in FlexCut panel on the plotter
