Smoke_Jaguar
Snagged a nice used cutter and am getting the thing dialed in. Loving the tangential and mostly been problem free. The Cutter Control workflow seemed to take some getting used to, but I am really liking it overall. Documentation is a bit lacking on these, but the standard user manual is pretty thorough overall.
Main issue was the dang noise, was pretty bad. Took off the toolhead cover and it seems the screw pulled out the plastic but that held it against the machine. So, might either go for epoxy if the part is unavailable or obscenely expensive. Getting it tightened down helped quite a bit, so no major complaint now. X/Y is still pretty noisy, so might see if there are things that need tightening. The servos they use look like something out of an alien spaceship, and the mounts have intentional play, so I want to avoid messing with that too much to avoid throwing it out of whack. I did clean the carriage rail, that was pretty funky.
So, blades, I know to avoid the cheapies for tangential. But, has anyone had luck with carbide? Didn't get any spares with the machine, but luckily the current one looks great under the microscope. Though, they can and will break, so will be ordering spares ASAP.
