Plans? Ha! We don't need no stinking plans!
![Tongue :tongue: :tongue:](https://signs101.com/images/smilies-orig/standard/tongue.gif)
LOL
Really...folks it's super easy. it's just one of those things you do by looking at it and then you add or take away details that fits your particular construction skills. It's all based on 4x8 sections, "tied" together to whatever length you want. Or, just use the one section, for you teensy garage space shops.
Here's a materials list of one of the many ways to build the basic frameworks:
1.) Sheets of plywood
2.) Angle iron
3.) 2x4s
4.) Nails, screws, hinges, wall anchors
Okay.....basically a section is comprised of two sheets of 4x8 material....a backer sheet and a top covering(discussed later)
The backer sheet can be made of regualar old 1/2" A/C plywood (you can get by with 3/8") then, attach 2" angle iron to the bottom for a "lip" to hold things (EVERYTHING!!!....yes, including finished signs Jen..hehe ) On the back of the top edge attach three strong hinges that you'll be, in turn, attaching to 2x4 material on the wall.
Snap a line at about "tippy toe" height on your wall. (Oh, remember you'll be standing about 2 feet back from the wall because of the slant of the easel.) This is where you'll attach those 2x4 pieces.....OR.....if you'd like, run the whole length with 2x4 material.....incorporating the wall anchors and existing wall studs (if possible) for this.
Hang your 4x8 section(s) on the the 2x4 material that is attached securely to the wall. Note * You'll need at least one extra pair of hands for this.
So, now.....you have a hanging section (or sections) on the wall just staring at you. Now what do you do? Well, first grab the bottom of your newly hung easel frame and get a feel for where you want to secure the angle.
Now, I have built these with and without storage racks. The storage racks are the preferred way....obviously. However, I have built easels that could "swing" at different angles....incorporating notched 1x6s attached to the floor. To do this you have to build an additional hinged-and-framed structure that "clicks" into the notches on the floor.
Either way, you guys get the basic picture.....figure it out from there. The way this works is..... you'll even figure out a better easel than I ever did. Have fun learning how to doing rest of it yourself. That's all I'm going to give you.
~Gear
