what you do when you see this
what you do when you red black blue is off
  • Get a nice head cleaning
    Votes: 57 60.6%
  • Reinstall color profile
    Votes: 5 5.3%
  • Call tech busted head
    Votes: 5 5.3%
  • go on sign 101 ask for help
    Votes: 27 28.7%
  • Total voters
    94
NazGraphics
what you do when your red black blue is off
jfiscus
Rap Master
I usually stop on red.
it'd be helpful to have printer/head info to help you out. It looks like you have cross-contamination in your heads. This can be caused by the drain tube or pump being clogged and allowing one color to flow back up into the other head's line while it sits son the capping station. (assuming this is supposed to be CMYK)
dubhcaora
one of your black heads is starved for ink or clogged to hell.
looks like you got a mutoh. go into the cleaning menu and give it a "little charge"
I found with mutohs, depending on your black ink limit, if you give them a slight pause in the interval time it helps with ink starving quite a bit.
half a second will do it. however on banner material I really never need to adjust for that.
bob
Maybe add another option: Adjust the media comp and droplet position. :omg:
Try to follow along here sport. The thing was working and now it's not. Unless the printer demons diddled the settings of which you speak without proper authority then why would you do such a silly thing?
bob
купить спайс детское порно фото проститутки иркутска снят проститутки проститутки волгограда проститутки омска купить огнестрельное оружие нарезное
Which, via a Cyrillic to English translator, comes out as "buy spice child porno photo prostitute Irkutsk [url = http://pravogolosa.net] removed [/url] escort, escort in Volgograd prostitutes Omsk to buy firearms rifles "
It would seem to be touting hot Russian babes and guns rather than any sort of sign issues.
eahicks
For starters, looks like this banner material is beige? Without a true (or near true) white point, you will have 'off' colors.
boxerbay
It all depends on what printer you are running. solvent - flush the heads. UV flatbed - could be an air bubble in your line. purge the lines. Canon AQ IPF9400 - put a new print head in.
mmblarg
I agree with most of the posts, looks like you have a clog. We have a Roland that does this - first time around we had dried ink in the line that needed to be pulled out. Second round, an ink cartridge didn't communicate with the printer and went bone dry without pausing the print. See if you can run a print test - usually will tell you which channel or print head is having an issue.
