1/2" acrylic push thru with flanges for aluminum faces
Oleeo
Hello all
Anyone using Vectric V carve pro to do this ?
Trying to figure how to do a rough and finishing path ?
GaSouthpaw
Not familiar with Vectric, but when I'm setting these up (in EnRoute), I do my files with layers for each tool (roughing, finishing, cutout, etc.). That way, I always have a "record" of exactly how any given job was processed ('cuz my memory is doodoo). I'm sure Vectric has a similar option.
If you're asking about the process itself, the old school way is to do an inline of the copy of approximately of .0313" +/- and use the smaller one for the push through, giving your outside corners a radius equal to the size of the bit you used to cut your faces (in general I use a 3/16" bit for cutting faces, so my radius would be 3/32"). You also need to do the same on any inside corner when cutting your face. After that, you run your finishing pass with the same sized bit that you used for your face.
If neither of those was what you were asking, then I totally misunderstood. In my defense, I haven't had my coffee yet.
Bradley D
www.jigsign.com
CHAT GPT SAYS:​
How to set it up​
  1. Create a Pocket Toolpath.
  2. In the Tool Selection section, click Add Tool (or the "+" button).
  3. Add your largest bit first.
  4. Add progressively smaller bits underneath it.
  5. Calculate the toolpath.
VCarve automatically calculates the "rest" material for each successive tool.
I love VCarve but don't hog things out much. I've never tried using mulitiple bits for a pocket toolpath but looks like it should work.
