1341sr pro wiper not working
Ronny howard
I think it is about time to change the station as it was done last in two years ago. But the issue I was having then and now is the wiper does not work? will not come up and whip Also is the station needing changed or just the cap?
Inkjetparts
cap and wiper are separate parts on these so a new cap alone wont fix the wiper not coming up. id pull the cover and see if the wiper is stuck with dried ink or the slider is gummed up, clean it and see if it frees up. any error on the panel when it goes to wipe? I work at Inkjet Parts, we have a 1641sr wiper swap video thats pretty close to that unit
Ronny howard
Yes sir I know they are not the same. I was just saying it is past time to replace the station, I think. The wiper part is all good just don't work. Nothing keeping it from working other than I think the solenoid it self.
dtfonestop
Sounds like you've already narrowed it down. If the wiper itself slides freely and nothing is binding, the solenoid or whatever drives it is the likely culprit. A few quick ways to confirm before ordering parts:
1. Watch and listen when the printer goes to wipe, at power-up or during a cleaning. A healthy solenoid gives a clear click as it pulls in. No click at all points to the solenoid coil, its connector or the signal from the board. A click with no wiper movement points to the linkage, latch or return spring between the solenoid and the wiper.
2. With the power off, unplug the solenoid and check the coil with a meter. No reading at all, or a dead short, means the coil is gone. A normal resistance reading means the coil is probably fine and the problem is upstream.
3. Look at the cable and connector going to it. After a couple of years, ink mist and flush can corrode the pins, and a cable can get rubbed through near the station. Reseat it and check the pins for any green or black buildup.
4. Clean the plunger. Dried ink on the plunger shaft can make a tired solenoid stick, so wipe it with flush, make sure it moves freely, and confirm the return spring is still in place.
If the coil measures bad, a solenoid alone is a cheap fix. Since you were planning a station anyway after two years, a complete station gets you new caps, wiper, solenoid and tubing in one go, which makes sense if the caps are getting hard or not sealing well. If the caps still seal and the pump pulls ink during a cleaning, the solenoid alone will get you running again.
Either way, run a cleaning and a nozzle check before the first real job, since the heads haven't been wiped properly for a while.
