16" decal pricing
KPC
I'm looking to get an idea of what the going rate might be for a 6 decals like this 16" wide.
2 decals cut / weeded / taped from oracal 641 blue
2 decals cut / weeded / taped from oracal 641 black
2 decals printed using a roland pc600 on oracal 641 white using spot silver ribbon then cut / weeded / taped or possibly not print at all and just cut out of a brushed aluminum vinyl & weeded / taped.
FWIW, this is the first that I've ever used this equipment to do anything for someone else. I bought the machine with intentions of only doing my own vinyl work but this one guy found out through my family and asked if I could make a few decals. It is a pretty simple design and he even was able to provide a cad file with the design, however it didn't open perfectly with Corel, so I had to clean it up and pretty much completely recreate the graphic myself.
Because I'm still very green, it did take me over an hour to recreate the file but I can't see how I should charge for a full hour to recreate such a simple graphic.
I'm thinking that for RTA, $30 for each of the 4 non printed / cut decals and $38 for each of the two printed / cut decals sounds about right?
I'm also thinking that, should the guy decide these prices are already too high (I'm guessing this is going to happen), and he decides to downsize from 6 decals to just 1 cut decal, i'm thinking the price should go up to $40 for just the 1 cut decal.
I'm basing much of my price not on material costs or difficulty of design, but rather it is a pita to weed because of the super fine detail and 1/4" small fonts.
I hope that I'm in the ball park for pricing.
I appreciate and look forward to any / all advice.
PGSigns
You are at less than 2 square feet for the cut stuff. On intermediate I would be $7.50 each and not sure why you would print 2 unless there is something I am missing in the design.
Jimmy
KPC
$7.50 to me seems low. The lettering is just a hair bigger than 1/4" and on the initial try, it took cutting 3 in 641 just to have one turn out perfect. Weeding these decals you practically need a microscope.
If these were easier to weed or if I could have just printed them, then $7.50 seems a little easier to swallow.
Anyone else agree with this?
by the way, the guy wants 6 decals.
2 black
2 blue
2 in what he said is (some sort of silver) I could possibly first print in spot silver then cut around each letter, just cut them from brushed aluminum appearance vinyl.
Jackpine
I'm not sure how they will be used but I would have them printed. It sounds like no matter how you do the job, you have too much time it now. You can have all 6 printed/laminated and cut to as a rectangle easier and cheaper than the vinyl approach. I won't weed 1/4" vinyl for anyone if I don't have to.
KPC
All 6 must be out of cut vinyl. The guy doesn't like the idea of a bumper sticker, he wants just cut vinyl.
red91_sc
I am with Geiger on this one , $7.50 is what I came up with also but that is with oracal 651. I tried using 641 on a smaller decal like that once and it was so much of a pita to weed that I ordered 651 and 751 and now only use them.
Jackpine
Then cut with HP vinyl with a 60 degree blade and reverse weed. If it is still difficult....cool the vinyl, refrigerator or freezer, and the vinyl will contract and you will see the cut lines. Bring back to room temp and weed. It still doesn't seem like much $$$ for the effort. Good luck.
KPC
My primary concern is what I should charge. I can't see how something like this could go for $7.50 when the initial design is more than just text only and after it is cut there is so much human labor involved with fighting the really tiny letters.
Granted, the machine does the cutting, but to weed such tiny font with intricate details isn't fun. Don't you guys/gals factor in the level of headache into your pricing? Even with materials being under $1 per decal, you barely make enough to get a sandwich for lunch at $7.50.
I read so much on here about how people sell themselves short. I feel that my time and equipment is worth more than only $7.50 per decal.
ENTDesign
On small jobs like this, the individual pricing should be compared against your shop minimum charge (which you need to determine). Charge whichever is higher. This allows you to spend time on small jobs people need without working for free.
Also, you are correct that you should not charge a layout fee based on longer time taken due to your inexperience. Estimating how long design work should take is a hard thing for you to gage when just starting out. You need to determine a minimum charge for design work. I use $30 as a minimum for jobs taking up to 30 minutes (my shop hourly is $60/hr, but you might need a different rate based on your circumstances. Search the threads, there are some good discussions on how to set hourly rates). I am guessing I could have taken the customer's logo and recreated it in 15 minutes (been doing design for quite awhile), but customer is going to pay the minimum or supply cut ready art.
KPC
ENT, thanks for the great post. It appears that the $30 quote is in the ball park for each decal.
Ogriv
At 30 bucks a piece, I know that I couldn't find a customer that would pay that.
This is such an easy piece, it should not take more that 1 or 2 minutes to weed. I make many small (3" x 3") text only graphics for a local golf cart retailer, and the text on it is as small as 1/4". I will weed 20 to 30 at a time. Perhaps you need to practice a little on your weeding technique? Perhaps your blade offset is set wrong and not completing the cut? The customer should not have to pay for your learning curve. These decals would not leave my shop for more than $10 at a quantity of 2. Unless I'm missing something, it's just text and some different sized curved lines.
mystysue
i say 10 each too.. I think you miss read ENT's post.. The shop mim. are for total orders not a piece..
WVB
We do these types of things EVERY day and at this size you would be at $10 each with a better vinyl Oracal 651. Also if this is somethig we designed artfree of $25 would be added depending... As Ogriv stated check your settings and blade. Should not be an issue cutting these at all...
KPC
I'm surprised to see so many people trying to lower a price. Ha-ha...
Give me a lil' credit. At least I'm not out lowballing as some might say.
I don't know if this adds to the equation, but the person buying these isn't looking to sell them as a fundraiser. They are for a specialty application on a piece of top end audio equipment.
No different than another post that I read where a guy with a large yacht was looking to have it lettered. Many posted to charge based on the job and if the guy has $900-1200 to drop in the tank for gas for a weekend out, why would he care if a lettering job is billed at $1500.
If someone has the money to play around with high end toys, I don't think that $30 for a custom decal made to finish off their project audio system would be much of a sweat.
mystysue
Ok.. as i see it.. YOU asked what the going price is.. Many answered YOu.. and You then say we are trying to lower a price?.. I find your tude about it a bit irratating .. if you wanna know the truth..
Its like you got offended that others didnt see it as a 30.00 a piece job.
NO i dont care what its going on .. a 16 inch sticker is just that..
gvgraphics
At 16" we would get $12 each for them. Specialty vinyls we would get $16 each.
Also the difficulty weeding you are having is probably you or the machine. I just cut 1/8th" stars for a rc race boat and had NO problem weeding them. Looking at your decal, it should take you about 30-45 min. to cut, weed, mask and trim them out. That may even be a bit to much time.
KPC
Not offended, just a little surprised at the figures most quoted. When it comes to little stuff like this, I personally felt that there is a certain PITA factor and what are the decals being used for, that would have been entered into the price. Even when the plotter is perfectly adjusted, that can't help when the adhesive bridges the small cut line and when you weed the graphic it picks up one of those tiny letters and ruins the decal. LOL
I understand that it was said to reduce the temp of the vinyl to let it contract which seems like it might help. I haven't given it a try yet but will the next time I find a little time.
I know and admit that I have more to learn, and I did post this thread to get advice. However, before posting this thread I searched the topic to see if it was covered and I read and agree where so many people say that they sell themselves short. I understand that some shops have minimums which in my eyes are about the only way to actually make a profit on a job like this. But where the others who will do a decal like this for $7.50, no setup fee, no minimum, that is in the flipping burger money making range. In my newbie opinion, I don't think it is right to allow these small jobs to get away at near free and expect that only the bigger jobs pay for the equipment and in a sign shops case (utilities, rent, much bigger / expensive equipment, overhead, etc.). I'm not looking to produce these decals to pay for the equipment and I don't have utilities, rent, overhead etc. In my case, I could be just a friend and give them away. But I still had to work hard to buy this piece of equipment and in the past several months I've read as much on this forum as my spare time allows me to do, and that in itself has a certain value.
I'm sure if I ran a sign shop and business was slow or the customer understood the decal would be done in an off time (come back in a day or two), I could see $5 per decal is just a few extra bucks that would otherwise not have made, but to spend quality time doing work like this at such a low price doesn't seem fair.
If this is coming across as a "tude", well I'm sorry, because it isn't how it is meant. I'm not looking to get anyone upset or stir the pot. I was just surprised where some were at the $5-12 range for a 1-off decal. I figured that would be a price when a few dozen were ordered at a time. That is all. :thumb:
