1614 maintenance station question
Graphics2u
So basically my question is, Should you be able to push and pull cleaning fluid through the waste ink lines coming from the pump with out the head sitting on the maintenance station?
I thought I used to be able to do this. I recently replaced the entire maintenance station about 6 weeks ago and ever since I just felt like it wasn't working up to par. Today I was doing a head cleaning and after wards it was awful on the nozzle check. My black has been giving me trouble for a while but I've managed to get by. After the cleaning there was almost no black and every other color was missing lots of nozzles which were fine before the cleaning. I did it again and it seemed to be even worse. Looked at the bottom of the head and there are all kinds of little drips hanging from it. Even some black ink was syphoning up the yellow, cyan and magenta nozzles.
I pulled the pump waste lines off and tried to suck through them with a syringe and couldn't. so I then tried to push air back through the lines and couldn't. finally one of the made a popping noise and I was able to push and pull air through the one line but never could through the other one. Then I pushed and pulled cleaning fluid through the one open line. This maintenance station has only been used 4-6 weeks and was brand new.
I've heard that popping sound a couple of times when it's running cleaning cycles in the past few weeks. Like a line all the sudden opened up.
Finally i just printed large sections of cyan, magenta, yellow and black and finally the head gradually came back, except for the black issue I've been having anyway.
Any ideas on this? Did the pumps change on the maintenance stations? I've had issue with the tiny lines and openings in the cap get clogged up but that usually after a couple years of use not 6 weeks.
