1mm rigid cutting options
SteveHem
Hi, Ive been producing health and safety stickers for afew years with my Vs540 and Fc9000 which is going great. Im looking at getting a Mimaki Uv roll to roll printer soon as i need to be able print white and gloss.
My question is: I want to be able to offer the same designs on 1mm rigid pvc boards. I have no idea what the best process would be, should i print on to vinyl, laminate and then apply to the board or look at a flat bed printer and print direct?
Also how can i cut the boards? Most of my designs have rounded corners and many are circles etc.
Any suggestions would be most appreciated. Thanks Steve
victor bogdanov
You can do easily do by printing on vinyl and applying to the board. If you have an application table makes it even easier, takes me about 30 seconds to apply 4 x 8ft vinyl onto a board using an application table. You would need a lot of volume to justify a flatbed printer
For cutting you will need a flatbed cutter
SteveHem
Thanks. I do have an application table but the signs i need to make are like say 10" x 8" need to have rounded corners. With the 1mm pvc boards do you just cut with a stanley knife and snap?
TEN
1mm PVC can be cut by hand with a Olfa knife and straightedge but it is hard to hand-cut into shapes beyond just straight lines. A flatbed cutter or router is what is needed.
  • Agree
Reactions: 1 user
