1st time doing a trailer wrap
RockstarATL
I am helping a friend do a wrap on his 18 x 7 trailer. I have the image but need help getting it ordered correctly as far as OVERLAP and other general questions. I am willing to pay someone to get it ready to order the 1t time around. Thanks
ElfringbE
Hello, can help you out as I mainly setup for fleet.
Would recommend 2" bleed for all four sides.
So file size needs to be 220" x 88". As for tiling & over lap what size media are you planning to print on? Sop overall at my shop is .25" but your mileage may vary. Let me know & I can work out the panel widths if you're not using a rip to tile the file
signheremd
Measure the panels on the side of the trailer - most use 48" wide panels, because of this you can set your printed panel width to give you overlap but then trim at the end of each panel to give a seamless look. Almost no reason for seams if you plan correctly. Use an air release vinyl, can be polymeric calendared to save money or cast if you prefer. I would use a good UV Wrap Laminate on this. As example, Oracal 3551 Rapid Air is a polymeric calendared perfect for a case like this, topped with OraGuard Gloss 290 cast wrap laminate will have a 7 year warranty.
ElfringbE
If you want to have panels printed at the same width with .25" overlap for either 48 or 54 the panel width size would be 44.40" wide for a total of 5 panels. If you're not using a rip here is the math
Panels 1 & 5 at 44.15" + .25" = 44.40"
Panels 2-3-4 at 43.90 + .5" = 44.40"
If you're using a rip, tile & add overlap at the rip
Using Avery vinyl & overlamo here
Good luck
