2:1:10 edit!! Error 01:02:10. L28500
balstestrat
Problem Solver
How did you end up figuring "trailing cable or the PCA" when it's pointing to the ISS??
Could be loose connection from the previous repairs or ink leakage etc.
tomz525
ISS PCA
MonsterBabyBLN
fair enough after checking all connections.. and the cable.. I restarted..
and it now DOES throw the 01:02:10 error.. lol.. I am pretty sure it was the other one first..
but never the less.. I put in new cartrdiges.. same.
MonsterBabyBLN
ok:
so I saw it stoped the initializing process at 37%.. all LEDs were on but the lower one for the 24V supply on the PrintMech..
I replaced the 24V power unit.
same
I replaced the main power unit.
same.
I replaced the printMech.
it booted up all the way.. and then beeped with the same 1:2:10 error..
is this strange that the error always occurs at a different stage?
MonsterBabyBLN
just did. same 1.2:10 pops up.
I did start the service menu .. and as soon as I go into the Ink sub menu.. test inks.. the error pops up
I might have to replace the whole system ?
MonsterBabyBLN
now I replaced the top ISS with one from another printer.. and get 59:2.0... used item .. is there a way around?.. I think theres an EPROM on that piece.. might be the problem ?
MonsterBabyBLN
Sorry.. I have no clue what you are trying to say.. lol**
I heard the ISS is matched with the HD.. so I replaced the HD as well.. and it seems to have solved the problem
It just wont restart anymore.. because now I have a paper jam error..
lol.. the printer started to make bad noises when forwarding.. coming from the right side and the main drive roller!.
looks like a tough job - again
