2016 Ford Transit door handles
def328
Trying to get the exterior door handles off. Anyone know how to remove them? I've searched everywhere and found nothing on later generation vans.
Thanks in advance!
JoeRansom
They are pretty easy , I can take pics tomorrow on one. There is a plastic oval on the inside edge of the door. You pop it off and use a I believe a t-20 bit and loosen the screw and the main piece where a lock would be at comes out then the handle slides out after its out.
Thanks in advance!
Sent from my SAMSUNG-SM-G900A using Tapatalk
Modern Ink Signs
Remove the black rubber cap/plug on the inside of the door. You can then access the torex screw. Loosen until you can remove the small end of the handle. Pull the handle open and toward the edge of the door at the same time. This will allow you pull the handle out. Reverse this process when putting the handle back in.
JoeRansom
Used a t20
JoeRansom
Should be noted the side entry slide door is a little different. And it uses a t25
